>>>DIRTY.CLAN.TERRORIST<<<
Re: >>>DIRTY.CLAN.TERRORIST<<<
Post by Fat Cat » Fri Mar 18, 2011 11:05 pm
[-X
Post by Fat Cat » Sun Mar 20, 2011 7:06 am
2011.03.19AM; jiujitsu...rolled with a big 240 lbs. blue and then a scrappy purple, both no-gi. I didn't have it in me to play creatively so I just stuck to my most basic pressure game. Rolled in total for about an hour.
Afternoon I did the following strength workout (day 17). I did the swings first actually, to relax my back after wrestling.
1. Deadlifts 2 x 5 @ 190 lbs.
2. Press 2 x 5 @ 100 lbs.
3. Curl 2 x 5 @ 70 lbs.
4. 1H KB Swing 1 x 20/20 @ 36 lbs.
5. L-Sit 1 x 5
Time: 21:46
Aloha!
unknown
Corporal
Post by unknown » Sun Mar 20, 2011 7:46 pm
so fatty,what advantage do you have with this weight training?
especially (sp) from deadlift and swing and the whole routine?
i'll send you one routine(note: not mine).
alex
eurofaggot
Post by Fat Cat » Mon Mar 21, 2011 9:03 pm
Thanks Alex, I liked what you sent me. You should post it in the nuggets section, or if you prefer, I could.
unknown
Corporal
Post by unknown » Mon Mar 21, 2011 9:26 pm
if you want to post it,great.
problem is that i never tried it. the exercises are great but idk about sets and reps.
it seems a spin on GVT.
i found the program on the UG forum years ago, so buyers beware.
when you have the time:
what advantage do you have with the weight training you currently are doing?
especialy from deadlift and swing and why did you choose those exercises?
it seems a spin off of dan john's workout.
thanks
eurofaggot
Post by Fat Cat » Mon Mar 21, 2011 10:01 pm
I've done the Don Blue 10 x 10 workout with good carryover to my grappling.
Re: this current program; this is my version of the Easy Strength program Dan John posted about. It's alright, but I started out doing it with dips and chins, but my shoulder started to hurt so I changed to press and curl. It's too early to judge this though, but I chose it because I wanted to do some lower rep work.
Post by Fat Cat » Tue Mar 22, 2011 6:47 am
2011.03.21PM; jiujitsu...rolled against a solid blue from Hanalei for a while and then practiced a Cornish wrestling throw for kicks, the Back Crook (kliked adrenv in the old tongue, apparently).
The back crook is like this: left hand grips his belt in front, you grapevine his left leg with your right and then throw you right hand over his back for as deep a grip as you can. He can't run behind you to your right because his left leg is entwined with your right leg. Then you take a hop on your free left foot 90-degrees clockwise and load his weight off his feet onto your left, twist and dump him on his back to your 5 o'clock direction. There's a similar throw in SAMBO and it's famously injurious because you dump your combined weight on his ribs in a totally indefensible direction, i.e. you cannot break-fall.
I haven't hit it live yet, when I would go for it the guy would turn away as I would go for the grip over the back, in which case it was easier to just grip a bodylock and up-end him. Fun to try though. I'm into these old European throws right now and some of them are pretty rough stuff.
Aloha!
Post by Fat Cat » Thu Mar 24, 2011 6:41 am
Dunn wrote:Folk wrestling styles. Growing up we played collar and elbow a lot, especially at family reunions on my dad's side. Just curious to see if there were any groups that had sprung up to make it a little more widespread. I will start looking around in the Southeast to see if there is anything beyond the Highland games stuff.
You know, the best way, the right way to do this is to research the art thorough and then recruit family, friends, and acquaintances with bragging rights, alcohol, and gambling.
Post by Fat Cat » Thu Mar 24, 2011 6:49 am
2011.03.23; strength training (Day 18). It was dark and raining so I did leg thrusts for my abs. All movements were done with meticulous form except the last single on the curls, which was ugly.
1. Deadlifts 1 x 6 @ [135>205>255>275>285>290]
2. Press 1 x 6 @ [95>115>125>135>145>155]
3. Curls @ [80>95>105>115>115>120]
4. 1H KB Swing 1 x 25/25 @ 36 lbs.
5. Leg Thrust 1 x 5
Time: 55:03
Aloha!
Post by Blaidd Drwg » Thu Mar 24, 2011 8:01 am
Mak,
I don;t know if it's that Fatherhood has been good to you or if it's the path you're on with JJ but there is undeniable wisdom in your practice. I admire that.
Now look, I've used my up all my sincerity for 2011.
Post by Fat Cat » Fri Mar 25, 2011 6:35 am
Thanks!
2011.03.24AM; running...ran four miles up a mountain, walked down. Aloha!
Post by Fat Cat » Sun Mar 27, 2011 7:36 am
I have comps next week Saturday so time is tight.
2011.03.26AM; strength training (Day 19).
1. Deadlifts 2 x 5 @ 210 lbs.
2. Press 2 x 5 @ 115 lbs.
3. Curl 2 x 5 @ 95 lbs.
4. 1H KB Swing 1 x 25/25 @ 54 lbs.
5. L-Sit 1 x 5
Time: 20:22
Aloha!
Post by Fat Cat » Mon Mar 28, 2011 6:31 am
2011.03.27AM; running...ran four miles up a mountain and then walked down. Running like this once, and at maximum twice, a week is definitely a solid way to create a base of cardiovascular fitness. It's not quite steady state because the incline varies, although never disappears, but definitely builds wind.
Aloha!
Post by Fat Cat » Wed Mar 30, 2011 5:03 am
2011.03.29AM; strength training (Day 20)
1. Deadlifts 2 x 5 @ 225 lbs.
2. Press 2 x 5 @ 120 lbs.
5. L-Sit 1 x 5
Time: 22:43
Aloha!
Post by Fat Cat » Sat Apr 02, 2011 10:13 pm
2011.04.02AM; strength training (Day 21). Finished my comprehensive exam for my master's degree at 10:45, was working out by 11:00. It was far too beautiful a day to be doing presses inside, so I decided to see how my body would react to going back to dips and chins. Dips felt fine, chins a little less so.
2. Ring Dips 2 x 5 @ bodyweight
3. Ring Chins 2 x 5 @ bodyweight
4. 1H KB Swing 1 x 30/30 @ 36 lbs.
5. L-Sit 1 x 5
Time: 20:37
Aloha!
judobrian
Post by judobrian » Sat Apr 02, 2011 11:12 pm
Congrats on finishing your comps.
Rain don't change the sun...
Post by Mickey O'neil » Sun Apr 03, 2011 3:06 am
Congrats!
Post by Fat Cat » Sun Apr 03, 2011 3:40 am
Thanks guys, I appreciate it.
2011.04.02PM; running...was pretty jacked so I did go running for a second workout, four miles mountain running, walked down.
Post by Fat Cat » Mon Apr 04, 2011 12:00 am
2011.04.03PM; strength training (Day 22).
1. Deadlifts 2 x 5 @ 205 lbs.
4. 1H KB Swing 1 x 20/20 @ 54 lbs.
5. L-Sit 1 x 5
Time: 19:28
Aloha!
Post by Fat Cat » Tue Apr 05, 2011 6:41 am
2011.04.04PM; jiujitsu...schedule is opening up so it's back the front for me.
Took a class on grip fighting to finish the choke when you have taken the back and he is resisting strongly. Finished up rolling for half an hour with a blue belt and then bouncing out. I felt very stiff so I purposely left before I was tired.
Aloha!
Post by Fat Cat » Wed Apr 06, 2011 7:28 am
2011.04.05PM; strength training (Day 23).
5. L-Sit 1 x 5
Time: 18:18
Aloha!
Post by Fat Cat » Thu Apr 07, 2011 7:52 am
2011.04.06PM; jiujitsu...3 hours rolling and training with Rhalan Gracie. Aloha!
Post by Fat Cat » Sun Apr 10, 2011 1:41 am
2011.04.09PM; strength training (Day 24).
1. Deadlifts 1 x 5-3-2 @ 205-255-285 lbs.
2. Ring Dips 1 x 5-3-2 @ 215-220-225 lbs.
3. Ring Chins 1 x 5-3-2 @ 215-220-225 lbs.
5. L-Sit 1 x 5
Time: 36:26
Aloha!
Post by Fat Cat » Sun Apr 10, 2011 2:18 am
Post by Fat Cat » Tue Apr 12, 2011 7:06 am
2011.04.11PM; jiujitsu...participated in a group class on attacks from top side, which I like a lot.
After that rolled with a very big, quite talented blue belt from Nova Scotia visiting on vacation. He had a very good guard, immediately after we shook hands he gripped me, pulled a big sweep and then took my back, then mounted me haha. But it's cool, I got out and then I pretty much asserted myself from there and took him four nill. The one time he tried to stand I doubled him nicely. But he was really good and it's always a kick to play with visitors. He had a very new school Barra-esque underhooking type of game and once I caught on I knew the formula.
Aloha!
