Brief infrequent check-in
Post by odin » Sat Nov 20, 2010 7:41 pm
time online has taken a hit of late, but I'll try and update this periodically. I'm lifting, walking and doing mobility stuff.
Assume JM+meditation & a walk of sorts daily.
Current goals:
-Bench - 300 (way off)
-Squat - 450 (50lbs or so off)
-Deadlift - 500 (50lbs or less off)
-Clean - 225 (no idea)
bw - sub 190lbs
past week:
16/11
walk in hills, 3 hours
18/11
1a. Push Jerk (cleaning from floor each set) - 50kg x 2 x 5, 62.5kg x 3 x 5
1b: Fat Bar curls - 20kg x 2 x 5, 40kg x 3 x 5
2a: TBDL - 116, 156kg x 5, 176kg x 3 x 5
2b: FSQ - 60, 70kg x 5, 82.5kg x 3 x 5
3a: Weighted chin - bw+7.5kg x 5,5,4
3b: Weighted dip - bw+7.5kg x 8,8,6
19/11
90mins walk
20/11
1. warm up with 3 rounds of light med ball circuit:
-OH throw x 10
-Wall ball x 10
-chest pass x 10
-slam x 10
2. TGU - 32kg x 5L/5R
3. OHSQ - 40kg x 3 x 8
4. Heavy wall ball - 10kg ball x 30 reps total
5. KB Swings - 32kg x 3 x 12L/12R
Re: Brief infrequent check-in
Post by Mickey O'neil » Sat Nov 20, 2010 10:08 pm
I had been meaning on checking in with you. Glad to hear you are doing well.
Post by odin » Wed Nov 24, 2010 2:16 pm
cheers, how's things with you? How did BLABA go for you?
Past few days:
21/11
20 mins mobility circuits
22/11
mobility and walking
23/11
1. JM + BB complexes to warm up
2. Power cleans - 50kg, 60kg x 3, 65kg x 3 x 3
3. BSQ - 60kg, 100kg x 5, 125kg x 3 x 5
4. Bench Press - 60kg, 70kg x 5, 100kg x 3 x 5
5. Fat Bar Power Row - 55kg, 65kg x 5, 85kg x 3 x 5
6. Rope pull - 3 sets, 20 secs
quick and easy session.
24/11
JM & walking
Post by Mickey O'neil » Wed Nov 24, 2010 4:44 pm
Next week is my last week on BLABA and I definitely like this program. It's going very well. Will do it again at some point.
Post by odin » Fri Nov 26, 2010 3:59 pm
cool, will take a look at that for the new year when I get a sec.
25/11
1. 20 mins mobility circuits/CC style stuff
2. 45 mins walk
26/11
am: sun salutations - fancied a change from my usual jm routine so did this before my sitting med. Was good.
pm: gym
warm up with mobility and bar complexes
A1: Push jerk (clean from floor each set) - 40kg, 50kg x 5, 65kg x 3x5
A2: Fat bar curl - 15kg, 35kg x 5, 42.5kg x 3 x 5
B: TBDL - 116, 156kg x 5, 181kg x 3 x 5
C: FSQ - 60kg, 70kg x 5, 85kg x 3 x 5
D1: Chins - bw+7.5kg x 3x5
D2: Dips - bw+7.5kg x 10,10,8
December is always a busy month, so it's good to be coming in somewhat strong & somewhat fit. Next few weeks will be even more infrequent and brief unfortunately.
Post by odin » Tue Nov 30, 2010 3:44 pm
28/11
1. JM work then 3 rounds of light med ball circuit:
-wall ball x 10
-OH throw x 10
-chest pass x 10
-slam x 10
2. 10 rounds of:
-KB 1/2 Sn - 32kg x 3/3
-Heavy wall ball - 10kg x 3 (15ftish target)
3. 2H swings - 32kg x 3 x 20
29/11
45 mins yoga
30/11
1. JM and barbell complexes to warm up
2. Power clean - 50kg, 60kg x 3, 67.5kg x 3 x 3
3. Back Squat - 60kg, 100kg x 5, 127.5kg x 3 x 5
4. Bench Press - 60kg, 80kg x 5, 102.5kg x 3 x 5
5. Fat bar power row - 45kg, 55kg x 5, 87.5kg x 3 x 5
6. Rope pull - 3 x 20m on max resistance, 1 x 40 metres on medium resistance
chi
Post by chi » Tue Nov 30, 2010 4:09 pm
Hey Odin, for some reason i get the impression your oop north somewhere. Have you ever been to Strength and Performance?
I'd say on the bottom of that self-actualisation pyramid shit, proper decent coffee is in there with wifi, tits, food and shelter
Post by odin » Sun Dec 05, 2010 10:58 am
I am indeed oop north. Not heard of that place tho - where is it?
Past few days training:
02/12 - cardio
JM then jump rope for 8 x 2:00 rounds with 1:00 active rest in between.
04/12 - barbells
JM & bar complexes to warm up, then
1a: Push Jerk - 40kg, 50kg x 5, 67.5kg x 3 x 5
1b: Fat Bar curl - 15, 25kg x 5, 40kg x 3 x 5
2. TBDL - 116, 161, 183.5kg x 5
3. FSQ - 60, 70kg x 5, 87.5kg x 3 x 5
4a: Chin - bw+10kg x 3 x 5
4b: dip - bw+10kg x 8,8,7
doing some extra work at the mo which is quite physical so energy levels are lower than usual - hence also reason for reducing my top weight dl's to just one set.
walking today.
chi
Post by chi » Tue Dec 07, 2010 4:51 pm
http://www.strengthandperformance.co.uk/
Seems to be the main UK gym employing Defranco/Evn-Esh style training and social media whoring.
Post by odin » Thu Mar 17, 2011 10:03 pm
VERY infrequent check-in it seems...
Past couple of months have been yoga in the mornings, and barbell work 3-4 times a week.
Some highlights:
C&J 225lbs
FSQ 305lbs
Snatching much, much less than this
Wtd chin bw+45lbs x 5x5
Want to work towards a 250 c&j and a bw snatch (185 ish) in the next few months. FSQ & chins can just steadily increase, all being well.
Post by Mickey O'neil » Thu Mar 17, 2011 10:44 pm
Great work, odin!
chi
Post by chi » Tue Mar 22, 2011 8:39 am
good good O:)
Post by odin » Thu Mar 24, 2011 9:14 pm
cheers, I'd like to still post here daily as I like the feedback and exchange of ideas but time is short at the mo and somethings have to give! Thought I'd instead opt for a Bux-esque periodic check-in to reflect on general trends etc. Right now I'm trying to dial in my diet a bit to meet the needs of training without piling on needless weight - can't afford a new wardrobe apart from anything else...
