In short, not for me.  I suspect Casper isn't either, based on how similar they are.
1.  Not enough motion reduction...I bounce my wife around when I switch positions.  This is the dealbreaker
2.  Virtually no edge support.  I expected this, but it's really nonexistant.
3.  Is just as hot at the Tempurdedic
																					Leesa Mattress
Topic author - Lifetime IGer
Re: Leesa Mattress
I've been considering one of these.  Were you switching from a standard mattress, or had you used the foam ones before?
									Re: Leesa Mattress
Sounds like a bad stripper name.
												The best lack all conviction, while the worst
Are full of passionate intensity.
W.B. Yeats
W.B. Yeats
Re: Leesa Mattress
Tempurpedic.  It feels like a cheap camper foam mattress compared to the tempurpedic.  100 lbs vs 230 or so is the difference in weights.
I've had 2 cheap memory foam mattresses, both wore out rapidly with regular use, like within a year, one was a Serra of some kind. The tempurpedic is going on 13 years.
If you arent 200 lbs or more, maybe?
100 days to try.
100 days to try.
Re: Leesa Mattress
I dont see it lasting 10 years either
