Fluid In Ear
DrDonkeyLove
Topic author - Sergeant Commanding
Fluid In Ear
I've had fluid in my left ear for weeks. It's not bad and I generally only feel it when straining. Went to the doc for something else a couple of weeks ago and he didn't see any infection or such.
I've tried using some heat but that didn't help.
Any recommended home remedies that don't involve homosexual acts or death?
Mao wrote:Political power grows out of the barrel of a gun. Our principle is that the Party commands the gun, and the gun must never be allowed to command the Party
Re: Fluid In Ear
Just a dab of H202 at a 3% solution.
ab g-d wrote:I can't understand how, given the training they did, the cavemen beat the dinosaurs.
Re: Fluid In Ear
Could be a little piece of hardened ear wax trying to get out. Try flushing with a kit from the drug store.
Once I had a hair grow inward. When I got a hold of it and pulled it out, it was about 4" long! Problem solved.
Obama's narcissism and arrogance is only superseded by his naivete and stupidity.
Re: Fluid In Ear
For a couple years, I had occasional fluidy/bubble-wrap popping sounds in my left ear. Nothing helped or changed it, it just came & went. Finally, it went away & didn't return. In short, I can't help you.
The best lack all conviction, while the worst
Are full of passionate intensity.
W.B. Yeats
W.B. Yeats
- Contact:
Re: Fluid In Ear
I get this pretty regularly. I use a little alcohol to dry it out. Mine stems from swimmers ear.
DrDonkeyLove
Re: Fluid In Ear
I will try these things. Much thanks.
DrDonkeyLove
Re: Fluid In Ear
Protobuilder
Re: Fluid In Ear
This. The two feel somewhat the same.Andy82 wrote:Could be a little piece of hardened ear wax trying to get out. Try flushing with a kit from the drug store.
WildGorillaMan wrote:Enthusiasm combined with no skill whatsoever can sometimes carry the day.
Re: Fluid In Ear
Agreed. I get the waxy buildup about once a year. I think mine comes from wearing earplugs a good bit a work and it gets pushed in and causes a fairly uncomfortable sensation of fluid in the ear canal.Protobuilder wrote:This. The two feel somewhat the same.Andy82 wrote:Could be a little piece of hardened ear wax trying to get out. Try flushing with a kit from the drug store.
The liquid wax softener in the kits doesn't work worth a shit for me, the the doc told me to use the same squeeze bulb from the kit and use it to flush luke warm H2O2/water mixture into the ear. A few bulb fulls and it works like a charm. Almost instant relief when the wax finally gives way and the pressure goes away.
Re: Fluid In Ear
You feel ear pressure when straining? Make sure it isn't middle or inner ear.
Check any tension in TMJ (jaw) up high the back of it, ad high in throat. This can hamper the eustachian tubes from being able to drain the middle ear. Google eustachian tube drainage, may show some avenues that help. Good luck.
What lies behind us and what lies before us are tiny matters compared to what lies within us.
Ralph Waldo Emerson
Ralph Waldo Emerson
DrDonkeyLove
Re: Fluid In Ear
So.....
I tried the H2O2 to no avail and worked on tension in the jaw area along with middle ear things. I think it's a middle ear problem and don't know what to do about it other than be patient.
Thanks for the advices.
FWIW my tinnitus is frequently louder than usual and my blood pressure is up noticeably. It was something like 130/70 and now it's around 143/80. Doc is keeping an eye on it. Resting heart rate has gone from around 64 bpm to 78 bpm.
I think I inherited my father's cardio vascular system instead of my mother's. Surprised by how much it's changed in a year. Meh.
climber511
- Gunny
Re: Fluid In Ear
Wife just had this - doctor said simple decongestant for the inner in addition to the stated home remedies for the outer.
Re: Fluid In Ear
It'd be good to rule out a CSF leak. Can be a serious problem.
